vcRealStepProperty
Typed property that holds a value, limited by a pre-defined set of values.
Parent: vcProperty
| AllowedValues | list[Real] | RW | Gets or sets a list of step values for property. |
| DefaultValue | Real OR None | RW | Gets or sets a default value for this property. Value None means that an explicit default value is not defined. |
| Magnitude | Real | RW | Gets or sets the magnitude of a property's value. |
| Quantity | vcQuantity | RW | Gets or sets the quantity of a property's value. |
| Type | vcStepPropertyType | R | Gets the type of a property. |
| Unit | vcUnit | R | Gets the unit of a property's value. |
| Value | Real | RW | Gets or sets the property value. |
| waitFor | object | Real OR None value, Optional Keyword[waitTrigger = Boolean] | Blocks script execution until vcProperty.Value is equal to the "value".See moreThis function returns an awaitable task. It must be awaited. Parameters: value (object): Value that is used for comparison. When the value is equal to vcProperty.Value, the task completes. Optional: waitTrigger (boolean): False by default. When waitTrigger is True, the task will wait for the value to change first, before comparing it against "value". Otherwise, the comparison is done immediately and when the values match, the task will complete without blocking the script. Returns: Awaitable[List]: The task instance. When awaited, returns a list of event arguments that the event has been triggered with. |
| waitForNot | object | Real OR None value, Optional Keyword[waitTrigger = Boolean] | Blocks script execution until vcProperty.Value is not equal to the "value".See moreThis function returns an awaitable task. It must be awaited. Parameters: value (object): Value that is used for comparison. When the value is not equal to vcProperty.Value, the task completes. Optional: waitTrigger (boolean): False by default. When waitTrigger is True, the task will wait for the value to change first, before comparing it against "value". Otherwise, the comparison is done immediately and when the values do not match, the task will complete without blocking the script. Returns: Awaitable[List]: The task instance. When awaited, returns a list of event arguments that the event has been triggered with. |
